1 - 3 of 3 Posts
Hey yall,
I just picked up a 2007 Thruxton 900. Everything on the bike works great except for one weird headlight problem.
I started it up and drove it home with no trouble, but then the next time that I went to start it up, the headlight did not come on. All the other stuff--turn signals, brake lights, worked just fine and the bike started right up.
I switched from low to high and back--nothing. I jiggled the wires going into the back of the light--nothing. Then I slapped the front of the headlight, and it came on. It stayed on until the bike was shut off, and then had the same problem when I turned it back on again.
I started it up a half a dozen more times with the exact same results. Sometimes I would have to slap the light a few times, but it always came on and stayed on until the bike was shut off.
Of course, this solution was extremely temporary, and now the light won't come on at all.
Anybody have any idea what could go wrong that would cause such a peculiar problem?
Thanks,
joey
I m assuming connections point are not clean or loose. Open all wire connection behind headlight rub with wire brush gently - also clean back of bulbs while you are there. Report back and experts should be able to chime in.
Administrator
Welcome to the forum!
The Air Cooled Twins Talk forum is where you can connect with other Bonneville riders. The folks there will have the knowledge and experience to assist you. Introduce yourself there, post photos of your Thruxton, and engage the members.
http://www.triumphrat.net/water-cooled-twins-talk/
You will also enjoy the Club Cafe.
https://www.triumphrat.net/club-cafe/
Please complete your user profile so that we may see where you are from and what you ride as you post throughout the forums. Thanks!
http://www.triumphrat.net/profile.php?do=editprofile
Connect with local riders in the RAT forums. If you do not see a thread for your area, please start one.
http://www.triumphrat.net/rat/
You may also find local riders and local events in the Rides and Events forum.
http://www.triumphrat.net/rides-and-events/
Please share your home with us by posting photos of your rides in the Ride and Trip Reports forum.
http://www.triumphrat.net/ride-trip-reports/
Enjoy some off-topic and often humorous conversations in the Biker Hang Out forum.
http://www.triumphrat.net/biker-hang-out/
There is much to our forum, so please make yourself at home, browse the forums, and join the conversation where ever it may interest you.
Cheers!
1 - 3 of 3 Posts
