1 - 2 of 2 Posts
I've just bought a 2006 Thruxton which has had a slight misshap.
The original guages have been replaced with a digital readout which i really want to put back to original. She'll need the complete pod with including speedo, rev counter, warning lights and mounting bracket.
When the digital readout was fitted, they cut the wiring loom multi connector, so could realy do with the connector + a short length of loom to make a nice job.
Can anyone help??
She also needs the original headlight + mounting brackets and front indicators.
Really hope someone can help.
Many thanks
Steve
Veed - think you'd need to find a bike being parted out. Other than that, scan ebay, put in a "want to buy" ad - or install aftermarket stuff, which would likely be way cheaper in the end. TPUSA and newbonnevile/newthruxton, I believe, sells kits with tach, speedo, and mounting bracket. Check it out and good luck!
1 - 2 of 2 Posts
