Has anyone put a high quality fork on a Thruxton? I have seen Ohlins rear shocks for sale but not much for the front end.
I think "BonnevillePerformance" website offers an upgrade set of forks and triple trees, they're wider than oem and quite expensive.
FWIW, rather than complete fork replacement lots of people modify the existing ones by adding emulators, cartridge inserts or similar and changing springs.
Forks
There are people that have put on USD honda forks i believe from a 600 dont know which model. There is the speed triple forks that can be used. Of couse there is always the option of triple trees botn custom and of the shelf and if you get the right size then you could firt what you want.
Personally i agree with the others go and improve what you have.
Progressive springs, emulators/intimators(my choice), oils, spacer length etc. Then of course you can upgrade the bakes.
Let your heart lead you, hope the bank balance can follow!;)
