1 - 7 of 7 Posts
Greeting,
i ve 2015 thruxton900 I wanna replace the handlebar for the cross country run.(cruising). what are the best options. and is it wise to do so for the acceleration and cornering.
Changing your bars may mean getting longer cables. You could try handle bar risers which should allow you to save the cost and trouble of changing cables,
  • Like
Reactions: VVIKKAAS
Same as Stoanee. Pressure on my wrist was becoming unbearable. Read somewhere on this forum and tried it. Basically solved the issue, and would recommend before taking other actions. The slightly higher riding position, along with the added wind force provided by the taller stance significantly relieved the wrist pressure on my 6ft frame.
  • Like
Reactions: stoanee
1 - 7 of 7 Posts
