Anybody tried to balance throttles with Tuneboy? I'm lost.
Triumph manual says to:
- remove tank and airbox
- connect diagnostic tool
- temporarily refit fuel tank and start engine
- balance throttles
Now, because this is done with ECU reading what are the vacuum values, then it must use MAP sensor. But without airbox there is no MAP sensor! (it is mounted on airbox and disconnected to remove it).
If I put airbox back, then there is no access to adjustment screws...
Anybody knows how to do it?
- balance throttles
