1 - 9 of 9 Posts
G'day all,
Time for a new battery me thinks. I've had the bike over a year and haven't yet changed it. Maybe its me being paranoid but I thinks its not cranking as well as it used to cold.
Anyway, this is what I'm looking at -
Products
Motorcycles and Scooters
Maintenance Free
YTX14AHL-BS
YTX14AHL-BS Battery
Profile
The YTX14AHL-BS is a High Performance VRLA maintenance-free design – freeing you from the hassle of topping up your battery. High Performance VRLA batteries have a specialist plate design and extra battery plates to give you up to 30 per cent more cranking amps.
Special Features
* 30 per cent more cranking amps
* spill-proof design
* exceptional vibration and impact resistance
* reduced discharge for longer storage life
* maximum performance.
View Battery Description
YTX14AHL-BS Battery
Yuasa Range Guide
For more info, download the Yuasa range guide.
Do any of you guys have experience with this one? Good, bad or otherwise?
I have also ordered a new battery charger as mine got mangled when the bike fell on it. It still works but is held together with insulation tape.
Cheers, Roden
Discussion Starter #2
Eewww, my cut and paste didn't work too well, it was supposed to have a pretty picture!
Sorry about that....
Yuasa makes good batteries....I've got bunches of them here. For motorcycle applications the AGM/VRLA acid starved batteries (i.e., no liquid to spill) batteries are excellent. Cold cranking amps are good as well, and they are lower in maintenance than a flooded cell battery (traditional wet cell lead/acid). But, more expensive. But, NO ACID TO SPILL!
Keep 'em on a trickle charge, use current limited constant voltage chargers (a cheap charger on "high" can toast a cell....the initial inrush can cause chemical changes in the cells) or use the lowest setting on such a charger at first if the battery is low.
On TrackSquirt (playtoy 250 Ninja) I use an old 17 aH gelcell battery (AGM) with some connectors I whipped up. The battery came from a battery backup system...the company changes the batteries every year, and I get the "old" ones. The one I have for my camping ham radio is 4-5 years old and still works great. AGM/VRLA batteries are VERY good.....but just a bit more $$.
Derswede
Yuasa YTX14-BS is what's spec'ed for my Sprint, & I upgraded the Trident to some no-name AGM battery when old one started to go. Hard to go wrong with AGM, harder still with Yuasa.
-Kit
Thanks lads, thats what I thought. I'll price one up today.
I ordered a new "Battery Fighter" charger. Its a four step charger which doesn't cook batteries!
Roden
I owned a Guzzi for 20 years and it took a fair bit to fire it up on average a Yuasa would last about four years ,twice i replaced it with lesser and cheaper battery and i was lucky to get 12 months ,i would not use anything else .
Discussion Starter #9
I ended up buying as Deka AGM (Absorbed Glass Mat) Sports Power battery, 190CCA, 14 Amp/Hr. $198, ouch.
The bike fires almost instantly cold, now I realise how lazy it was turning over before.
Got a new 4 step Battery Fighter too, $60 delivered, good value.
Roden
1 - 9 of 9 Posts
