Hi all,
Never was any good at IQ tests that included engineering type tests so I really need to pick someone's brain on this.
Rebuilt my '72 650 engine with .020, 9:1 pistons. The head was shaved .004". I do not know the previous history on the head, viz, whether a previous owner had the head shaved also.
Achieved .060" sqeeze on the PRTs using the the smallest thickness neoprene seal, and a standard .040" copper gasket.
I am really wondering whether any of these changes from standard are likely to alter the piston:valve clearance. I am guessing it would not make any appreciable difference, but like I said, I'm a dunce when trying to work these things out. RR
The standard copper head gaskets are .048".
It is very unlikely that your pistons and valves will touch.
See:
http://www.triumphrat.net/classic-vintage-and-veteran/111099-nasty-clicking-sound-on-kickover.html
(page 10:eek:)
The plasticine in the piston recess confirmed I had 1/8" or so clearance, but I had fitted a .070" `extra thick` gasket. (There`s reasons for using this gasket, 9.5:1 pistons, etc).
This was a rather extreme situation, I think.
Refurbished head with new valves and seats, new barrels and pistons and no idea how much had been skimmed off.
Hi guys,
It occurred to my non-mechanical brain last night, that this is most probably more of an issue where vavle timing and lift are changed.
I am a worry wart for sure, but we all know these Triumphs have a capacity to let us have it in the neck if we drop our guard. Thanks again. RR
