1 - 12 of 12 Posts
I'm interested, if you don't mind shipping to the states.
Just let me know what shipping would be, and I'll use paypal on ebay.
Errm I think Johny was just alerting us - not advertising his auction. i.e. its not him selling it.
[ This message was edited by: MickMaguire on 2007-02-27 10:41 ]
Ummm.... if I had that item on my watch list and someone other than the seller publicises the auction, I'd be a bit upset.
I would agree, and normally I would delete this kind of post for that reason but it is a "buy it now" only auction so nobody is going to be watching and waiting to bid.
On 2007-02-27 17:38, Ballacraine wrote:
Thanks for the heads up Johny.
Been on the look out for one of those for quite a while on and off! :wink:
Got it, thanks.
Nige. :cool:
that's gonna raise the back of the legend quite a lot Nige.
Aye..I have an early Trophy swing arm to go on too..
The type with the eccentric adjusters....
So I will see what I end up with with that combination & take it from there!
As an aside.....Anybody any comments on where I am likely to end up seat height-wise? :???:
Be interesting to gather some opinions on this, as TBH I am some way away from starting the job.
There is an impending house move for starters! :(
Nige. :cool:
[ This message was edited by: Ballacraine on 2007-02-28 14:03 ]
Nige,
The Triumph manual quotes 725mm as the seat height for the Legend and 750mm for the TBird / TBS - I presume these measurements are for the early TBird with the sub-frame designed for the key-operated seat.
It's been a while since I sat on a TBird/TBS side-by-side, but subjectively I thought the TBS had about 25mm higher seat than my TBird, so I suspect you'll add at least 25mm / 1 inch to the height, but probably more like 50mm / 2 inches.
I would say 25mm sounds about right - I noticed the back of my Tbird come up quite a bit when I fitted the TBS shock. the shorter Trophy swing arm might compensate for that some.
Thanks for the input, Mick....
Sounds 'do-able' anyway.
Might be some adjustment :hammer:
of swingarm / shock / centre stand equation required. :wink:
Nige. :cool:
1 - 12 of 12 Posts
