1 - 3 of 3 Posts
My TBS suddenly started leaking coolant from under the refill cap. Normally it starts a couple of days after I last rode it and consists of not more than a few drops per day. I just ordered a new cap for I suspect that the problem is on the cap’s springs and/or seals. My question is if meanwhile I should ride it or not.
You may want to try a little silicone grease on the rubber gasket of the cap and keep your eye out for leaks and on the coolant level.
Thanks mate! I will do that and keep checking.
Cheers!
1 - 3 of 3 Posts
