1 - 2 of 2 Posts
Hello, my 2014 LT has recently had the bearings fail in the rear sprocket drive hub. It has 14,033 miles on it. I know that the earlier 2009-2010 Tbirds had an issue with this part. The factory service manual will give you a production number and tell you that this hub must be replaced at 24,000 miles. Mine is well past that number. Was wondering if anybody else has seen this issue?
Have not heard of this in later model birds like yours. It has been said that tight belt tension can be a contributing factor.
1 - 2 of 2 Posts
