1 - 14 of 14 Posts
I've seen the t-bird with the custom tank...I'd like to know if anyone has swapped out the modern t-bird tank with one from a bonneville/thruxton, older America/Speedmaster, or even an older
Thunderbird. Can it be done? People are putting bonnie tanks on the
America.
I seriously doubt it, because the Tbird has the fuel pump in the tank. Even if you were able to put another tank from another injected model with a in tank pump, the ECU isn't likely going to be compatible with it.
That custom Thunderbird (done by AlainP, or AlanP...something like that) is pretty awesome, but keep in mind that he made the tank to fit the dimensions of the bike. Even if you could somehow connect a Bonneville tank on a Thunderbird it wouldn't look right. It is just way to small and skinny to fit the bike.
I think you are right, but i thought an older tbird tank might fit.
yeah, but again, you can't do that especially with the older tbird, by which i assume you mean the triple, because those weren't even injected. So even if it were possible yo use a different tank from a injected bike of a completely different model, the old tbird has NO fuel pump. So it's impossible. As i said about thos even if you tried a bonnie or speedmaster tank, sure they have fuel pumps in them, but they are likely a totally different one that even if it mounted the same (VERY unlikely) they likely would not work with the Tbird's ECU
In short, you're barking up a tree thats not even there. It just ain't gonna happen, at least not without major modification and major $.
I understand what you are saying, but if you owned a FI tbird, you would have the
correct fuel pump to potentially put in the "other" tank. I doesnt seem that far fetched to me, if it would actually fit.
I don't understand what you are saying. There are 2 tbirds triumph has made since John Bloor restarted the company in the late 80's....the 900 triple and the 1600-1700 cruiser. If you are simply talking about replacing your tank with a different color from another 1600 or 1700 cruiser, then of course you can. But if you are talking about the 900 triple you would have to put the punmp in the 900's tank. You say it doesn't seem far fetched....well, have you seen your bike's fuel pump? Because i can tell you that if you have you would not be saying that it doesn't seem far fetched ! Take your tank off and look. And if that doesn't make you realize what i'm saying, remove the pump. That WILL convince you. I have removed mine, i know what i'm saying.
I personally don't see how you are going to get around building a custom tank. Any other route is going to produce something that either doesn't work, or doesn't look right.
Then why don't you go get another tank and try it and come back and tell us the results instead of talking lot of hypothetical BS.
Discussion Starter #11
I was curious. I dont own a Tbird, and ive only see one Fi one in person. I have seen a bonnie and an america fuel pump, and i know you can swap tanks on those bikes, so thats why i was wondering. Again, i have no idea the dimensions of the tbird tank, new or carbed. I guess they have a giant fuel pump. Just asking, i
like the look of the older tanks. Thanks.
Discussion Starter #12
That has to be the least helpful answer ive gotton to a question Ive asked on a forum. I thought forum's were all about questions and hypotheticals. Are you having a bad day or are you really that much of a donkey?
Wombat was a bit out of line, but I would guess that is due to the fact that your question was already asked, and you didn't like the initial replies. You are asking about doing something that is not feasible, so of course nobody is going to tell you that it is.
As for the Bonnie and America tanks being interchangeable I would suspect that is because those bikes utilize the same engine, and most likely the same computer. They have much closer DNA, so that swap seems more logical.
Discussion Starter #14
Thanks. I was just curious as to why it wouldn't work. Just trying to learn, not argue.
1 - 14 of 14 Posts
