can anyone provide the correct lenght size and letter size of the side gas tank triumph sticker?
a good paralel picture of the sticker would be fantastic
from jet black or matte black bike
best regards to all
and thanks for any help
The exact length of the decal is 170mm, or 6 11/16" from the tip of the 'T' to the edge of the 'H'.
See my pics for how they're positioned on my glossy black 2007. I stretched two strips of masking tape to act as datums - one across the centerline of the filler cap, and one 'underscoring' the "1050" decal, trying to keep them as perpendicular to the centerline of the bike as possible.
I held a steel rule under the bottom of the letters and scribed a line across the two strips of tape. That line passed through a point 6 3/4" from the CL at the front, and 4 1/8" from the edge of the filler cap at the back. Both of those measurements are true measurements around the curvature of the tank, i.e. I bent a whippy steel rule so it contacted the tank all the way around.
You can see from my sketch that the decals are pretty much centered about those two datums - 1/2" from the tape to the lower corner of the closest character.
Hope that helps!
wow fantastic help, this is all i need thanks a lot really
been whitout for my s3 for a month now... really miss it
noticed that the font of the triumph logo is a bit different from the 08/10 model
small restlying there
