1 - 8 of 8 Posts
Just a quick question. My tank on my Tbird is without the rubber pads. Anyone have a set sitting or know where they can find them?
· Premium Member
You can buy them from Triumph, not horribly expensive $45-$55 dependant upon the style you choose...
<BR>
<BR>take a look here
[ This message was edited by: MickMaguire on 2007-01-24 11:00 ]
· Premium Member
<BR>On 2007-01-24 11:51, KD5QOQ wrote:
<BR>How do they install? Self adhesive?
<BR>
<BR>yes - you should clean and de-wax the paint first (with some alcohol) but then you just peel off the backing and stick them in place. Warming the tank and pads a little with a hairdyer can help too.
[ This message was edited by: MickMaguire on 2007-01-24 11:55 ]
· Premium Member
On 2007-01-26 09:09, thaw wrote:
I have a pair off my '98 TBS, perfect shape, $40!
You can use ones that have already been used but to stop them peeling you really need to remove the factory adhesive and use a contact cement to fix them on. This can be a little messy and it will mean that removing them will most likely require a repaint, but it cant be done and works well.
[ This message was edited by: MickMaguire on 2007-01-26 09:59 ]
thaw said I have a pair off my '98 TBS, perfect shape, $40!
they're only 45 -55 per pair new , not 45-55 each i believe , the package i saw on the rack at my triumph dealer today i'm pretty sure had a pair in it .
1 - 8 of 8 Posts
