1 - 3 of 3 Posts
I believe if you can take the "Triumph" part off of the stock badges then I believe people double sidedtape them down. Much cheaper than buying the $100 '68 badges but the stock ones are a little smaller.
You'll have to fill in the screw holes and have it re-painted first. The inset "Triumph" is much smaller than the stock mounting holes.
rbrian_taylor - you can buy different style badges from dealers that will swap right on to your ride. You will need a tamper-proof torx bit (tool) to remove the stock bolts, and they are available at your local auto parts store for less than $10 (complete set).
1 - 3 of 3 Posts
