1 - 15 of 15 Posts
Ok, I've decided for a small winter project that I want to remove my rear fender, I'm not going the NewTruxton kit route, instead I'm going to build my own.
What I'm wondering is, where I can find a tail (brake) light that has it's mount points on the top such as the one in the NewThruxton kit. Do you guys know of a good internet resource for something like this?
I know there are a lot of "chopper" parts places but I'd rather get something brushed instead of chrome to be consistant with the indicators I'm ordering.
I know that the "upside down" mount brake light may be hard to come by, I plan on useing a piece of 1/4 or 1/8 abs plate where the fender is no so I might be able to extend it down and brace it to acomidate a bottom mount brake light.
Also, for you guys that have done them, did you reuse the stock wiring harness off the old tail light assembly or order a new one?
Thanks in advance for any answers or suggestions.
Guys,
Unfortunately I do not have a Thruxton seat with cowl to photograph with this fender. Maybe I can find a willing guinea pig to test-fit the fender and snap some photos (T1???).? The one's below are on a T100 with a solo seat.
Sweat: Bright... very bright
WV: The same company has semi-flush turn indicators and the fender has just enough side skirt to install them (as seen in photos).
Mike
I used 1/8 inch aluminum to form a bracket to mount the light and plate - it makes a 90 degree bend at the top and is bolted on with the two rear fender mounting bolts. Just spliced into the factory wiring. Stock rear fender cut down and painted black. A billet oval led was mounted that fits right into the curved brace between the 2 frame rails at the back of the bike.
John
Discussion Starter #13
Robnobrakes and Thrux-ton-up I really like those setup and it's what I'm looking to do.
Where did you guys find those brake lights?
Mine was supplied by Motrax.
Here is their website:
www.motrax.co.uk
Look in accessories: LED CYCLOPS
[ This message was edited by: robnobrakes on 2006-12-13 08:26 ]
1 - 15 of 15 Posts
