1 - 3 of 3 Posts
I've seen a kit from BC but wondering is there any other kits that let you add a tach to a 2007 Bonnie black that only has speedo? I would also like to mount it with a lowering bracket as well that keeps the idiot lights. I was hoping to have the tach match the speedo and not the small aftermarket ones
Sounds to me like you need a "flat bracket" made by D9 on this forum and a pair of Thruxton gauges (or at least the tacho)...
Tim
There's the Triumph kit for pre-EFI bikes, if it's still available, pretty much plug-and-play.
If you go the used part route for the Triumph kit, make sure that you get ALL the parts. This includes tachometer, replacement instrument wiring harness which includes lights for both gauges, gauge panel, different style odometer knob (which is necessary), and probably some other things that I don't remember right now..
1 - 3 of 3 Posts
