Trackometers
I would like to add a tach to my 01 Bonneville 790 but need info and tech advice. Can anyone help me????
Do a search in all the forums for tachs, you can get just the tach, a new bracket if needed for two gauges, a single tach mount with your speedo.....
there are several posts complete with instructions on mounting and wiring and places to get brackets.
If you get the Triumph tacho kit, it'll have good instructions and everything you need. If you buy it used, make sure that you get all the parts and bits, including the tacho wiring harness (which replaces the existing instrument harness), the gauge panel, and the different tripmeter knob.
Your bike being a 2001 might also need the separate wire for the tachometer, which comes in the kit. Read the directions to find out:
http://www.motorcyclestore.us/triumph/pdf/A9900173_EN-US_Tachometer[1].pdf
