1 - 2 of 2 Posts
Howdy folks. I'm told the FI system on the 97 T595 is not the same as the rest of the 955i triple engines. Is this correct? Has anyone fitted a later engine to a 97 frame successfully?
Thanks!
jetdocx, The '97 and '98 T595s are the same...mostly. Sometime earlier than my 1/98 built '98 there was a switch from a camshaft position sensor to a crankshaft position sensor. In '99 the ECM was upgraded along with throttle bodies, exhaust cam, primary tubes (clearance) and likely things I don't remember.
Brad
PS An engine swap may require a wiring harness andECM swap also.
1 - 2 of 2 Posts
