Hi,
I have a 1998 Daytona T595 with a gas leak at the small breather and overflow ports on the bottom of the gas tank. These little barb fittings have small flat rubber washers that cracked. After taking the fuel pump housing off to inspect I found the tubes for these barb fittings inside the gas tank look like they were sprayed completly with the same material as the gas tanks are made of. I dont understand how these barb fittings can leak gas. Anyone seen this before?
Thanks, Steve
Thanks, Steve
