1 - 3 of 3 Posts
Hi, I would think it's much the same as a T100 or my Daytona. Assuming it has a rear wheel driven speedo, it goes from the gearbox along the underside of the swinging arm and passes underneath. I normally put a Tywrap on it at this point to keep it clear of the rear tyre. From there it goes along under the gearbox, under the crankcase above the right hand frame tube and then up the front frame tube. A few Tywraps here and there to keep it neat, but avoid putting sharp bends in the cable. I've found some cables can be a bit short depending on the make. Check that the cable is right for your model year as there are differences. You're on your own getting it into the nacelle to the speedo itself!
Thanks, that is how I have run it - doesnt look very neat so I thought I may have it wrong!
1 - 3 of 3 Posts
