Hoping for some advice regarding my T140 I've recently aquired.
I did a compression check and got identical readings on both cylinders (warm) of 155 psi. I then put a few squirts of oil from my oil can and got readings of 170 psi, does that mean the bores are worn?
Sometimes (but not always) she smokes (more from the left hand cylinder than the right) when I blip the throttle, white/grey smoke, also black, I can sometimes get quite a cloud especially once she is hot. I haven't owned it long enough to tell what the oil consumption is like. The previous owner said the bike sat unused for the previous year and only shows about 150 mile on the clock since last MOT about 2 years ago.
What do you think, should I just ride the hell out of it?
Stewart
Stewart
