I have a '79 T140D that has began leaking at the bottom of the front pushrod tube quite a bit. Bike has 18200 miles and I'm looking to take the top end off this winter to check things out and renew the gaskets.
Is there one brand or version of gasket kit recommended. I've considered those from MAP Cycle and British Cyle Supply but would also look elsewhere if better.
