Can I disagree with you?I would wait to do the bushings until after the arm is painted or coated.
K
My friend you are welcome to disagree with anything I or anyone else out here says..... just be sure you have your ducks in a row.Can I disagree with you?
I confess I wasn’t planning to change those bushings, I just sent the whole frame for painting. The mechanic I use was professional enough to check my parts and recommended I do this job as part of painting the frame. He told me the bushings needed to be changed BEFORE painting, as there is a great chance you will ruin the paint. He explained these need to be reamed to size by a machine shop. Same with the camshaft bushings. The machine shop charged me about $60 to do the job, plus parts. Not the cheapest solution but at least I know it was done better that what I could have done on my own.
Just my 2c.
You are right, my ducks could be in total disarray :smile2:My friend you are welcome to disagree with anything I or anyone else out here says..... just be sure you have your ducks in a row.
What I got back from my mechanic was a swing arm with a copper colored bushing. They had some grooves inside that I figured were to help with the greasing. Those bushings looked like they had been reamed to the swing arm. What I understood is those bushings needed to be inserted (pre-size , reamed, hammered, etc.…) prior to the painting, otherwise the process of inserting the bushing could damage the paint. Not sure if that’s how they did in Meriden but that is how my guy does it. Might be worth mentioning that my frame was not powder coated, it was painted, which might be more prone to damage from inserting things. There might be more than one right way to skin this cow, I believe
Yup these bikes aren't rocket science.I replaced the swing-arm bushes on my '69 T120R in 2013 using exactly the instructions given in the workshop manual. No reaming, no press, no sweat. Must be pretty easy to do if I didn't have any problems.
Indeed, your pages are VERY interesting. Probably the best of its kind as far as I know.I replaced the swing-arm bushes on my '69 T120R in 2013 using exactly the instructions given in the workshop manual. No reaming, no press, no sweat. Must be pretty easy to do if I didn't have any problems.
