Hey all-
I ride a 2022 T120, and love it. I put about 6K on the clock last season, and plan to do the same or more this year. In addition to it being my usual daily driver, I use it for multi day touring. I do my best to stay off of highways and interstates, and mostly stick to 2 lane blacktop, i.e. no cruising, but generally more 'spirited' riding.
I've begun to get some pretty consistent tension/pain on the lower right side of my neck, just above the shoulder blade, sometimes after riding for less than an hour. So, I'm curious if others have experienced this with this bike, and if so, what have you done about it?
I have tweaked bar position a little bit (most recently rolling it forward and up), but have not been able to push it as far as I'd like to try, mostly due to interference from the ferrule of the master cylinder brake line hitting the right fork cap. The right control seems to have very little rotational movement available. I have worked on bikes in the past that have had an internal pin on the control housing that rides in a short 'limiter' slot in the handlebars, and so wonder if this is the case with the T120 controls. Let me know if you know before I take it apart to check.....
I looked at some past threads and the parts mentioned in those discussions, and it seems that some of those parts are no longer available, such as the short spacers, which seemed like the first option I would try, as opposed to 'real' risers or new bars.
As for me, I'm 6' 1" 180lbs, and have already replaced the stock seat with a British Customs model, which probably gave me a lift of maybe 3/4", which alleviated some minor right knee pain I was experiencing on longer rides with the original stock seat.
Any ideas or insights welcome!
Thanks,
ECJ
Thanks,
ECJ
