1 - 3 of 3 Posts
Good Morning and seasons greetings , I have a couple of questions.
I am putting a TLS front wheel on a '67 T100C that had a drum brake.
Q1. - Am I also going to have to find a set of later forks also? or will the wheel fit?
Q2. - Would I be able to fit 35mm Ceriani forks without any major engineering?
Any help greatly appreciated , Mango O'Heaney
'69 onward,the forks are wider and the axle is longer.If you fit a '66 - '68 axle on the new wheel,it will fit your forks.
1 - 3 of 3 Posts
