1 - 2 of 2 Posts
Hi guys... Sorry... that should be T90, not T09
According to the Parts List, my T90 uses two W653 bearings in the front wheel, two S35-7 and one W1041 bearing in the QD rear wheel. Can anyone tell me what the actual bearing number is for these, please (as opposed to the Triumph part numbers)
Depends on the brand what the part # will be. W653 is Triumph part# 37-0653, RHP #LJ20. Easier to locate by knowing the dimensions.The inner diameter is 20mm, outer diameter is 47mm and the width is 14mm. The W1041 is a 37-1041, don't know the dimensions. Call any bearing company with the dimensions and they'll have a corresponding part# for what you need.
1 - 2 of 2 Posts
