Hi, new to this.
i have a 2012 Thunderbird.Storm ABS and would like to fit a break modulator with interaction with the turn signals. I want to install a Kisan SM-1, but cannot find the turn signal relay anywhere. The circuit diagram appears to group it with the instrument cluster, but that appears to be a small assembly and I don’t want to dismantle it just to find the diagram was misleading.
Any advice would be appreciated.
thanks,
Phil
Sorry but you can't replace the flasher in a TBird; it's integrated into the instrument cluster circuitry. You can still install the brake modulator, convert to LEDs, etc. but you either have to accept the faster flash rate (it's only about 1Hz faster) or install power-wasting load equalizers.
Thank you very much for your response and sanity check. At least it ends my search on the bike. Again, much appreciate.
