I'm looking for some help. I've got a 2,000 T-Bird with about 18,000 miles. It has been a GREAT bike. It's always run great, without a single problem. It's entirely stock.
I have not been riding it much this last year. From July through November, I probably rode only 3-4 times. I keep the battery on a trickle charger, and idle it for 15-20 minutes every week or two if I can't ride, but that's it.
I rode some in December, and it ran fine. It always has started fine.
About 3 weeks ago, I noticed it start to run a little rough in mid-gears at fairly low rpms (around 3-3500 rpm). This bike has always been happy at about 3-3500 rpm. It's always run very smooth in that range, so the roughness was noticiable, even though not severe.
I've been riding 2-4 times a week since then, and the problem has gotten worse. It starts up fine, and runs ok at idle speed. When the engine speed is between 2500-3500, it misses and sputters a lot. At steady speed in this engine speed range, it runs ok, but will sometimes sputter a little. When I accelerate from this range, it's VERY rough and misses quite a bit. I can see the tach jumping around, going up and down 2-400 rpm at a time.
Once the engine speed is up above about 4,000 rpm, the problem is gone. Below 2,500 rpm, I'm not sure. At idle, it's ok, but there's no load on it. In 1st gear, it seems ok as I start from a stop. Other than that, I'm never really spending time below 2-2500 rpm, so I'm not certain there is a lower end to the engine speed range in which this problem occurs.
I've read a lot of posts, and I'm about ready to try replacing the coils. The spikey tach sympton is what first made me suspect an electrical problem, rather than fuel. Plus, the problem is isolated to only a range of engine speed, and it seems like a fuel problem wouldn't do that. I'm no mechanic, but that is what I was thinking.
What do you think? I would really appreciate any suggestions. If I replace the coils, should I replace the plugs, too? Would a bad plug do this? I understand why bad coils might act this way, but I can't see how a bad plug could cause this. But as I said, I'm no mechanic, just a guy who loves his T-Bird and wants to get her running smooth again.
BTW, there aren't any Triumph mechanics anywhere near here, so I'm hoping to take care of this myself. If I should replace coils and/or plugs, what replacement parts should I use?
Thanks.
Thanks.
