Dirty or clogged pilot jets. You'll need to remove the carbs.
Jim
Jim
Dry carbon deposits on the plugs point to a bad mixture or excessive time with the choke on. On a normally tuned engine in good condition, the carbon will usually burn off during normal operation.They were dry carbon deposits. Not all were fouled, though. The mechanic mentinoed that it was the carb "float" problem. Any views.
