1 - 2 of 2 Posts
hi guys i changing out my swingarm as the one i had was cracked and im putting the main pivot rod for the swingarm in right now and i cant fit the center spacer between the frame to save my life..its way!! too tight.. and fortunately theres no room in there to use anything to force it...what should i do? thanks
Where was the crack? Could the swing arm have flexed and changed the frame in any way?
Is it the same spacer that came out of there? Maybe put it in place first and then install the swing arm?
1 - 2 of 2 Posts
