Can anybody confirm what the distance between the rear forks on the swingarm should be on a t120r 1966 vintage ?
In the manual it says 7 1/2" but I measure mine at7 3/4" which wouldn't be such an issue except my newly built rear wheel is about 1/8" wider
Before I try to press the forks apart I wanted to check if the wheel is too wide, or do the fork widths vary ? Thanks
