My suggestion - powercoat the original top clamp black to match the bottom one and order the headlight and instrument cluster mounting bracket from GSG / Wild Hair that fits to the original Triumph clamp only to achieve some of the same attributes.
Much cheaper $200 instead of $1500, but admittedly, not as hard core looking as this assembly.
Mind you, Oldsquid is working on something along these lines that he is planning to market for a lot less that the GSG version so should be interesting
[ This message was edited by: andylav on 2007-02-01 05:11 ]
For $1500 you could have your forks completely reworked by Thermosman...
or
For $1500 you could be halfway to buying a set of ohlin's forks...
