Hi
New here, so hi everyone.
I stripped my 1050 St down to tidy it up a bit and it has left me with a couple of questions:-
I aggressively cleaned the corrosion off the front wheel, rear wheel, swing arm, but the subframe is particularly bad. I got the paint off and the corrosion is all over the tubes, but none on the end bungs, welds or flat brace, I guess the tubes are.... of a different material with zero corrosion resistance, probably high in magnesium. Does anyone make a decent replacement for the subframe with a better corrosion resistance?
The other issue, (same one as with the 955 ST/RS SSSA), is the swing arm / shock linkage spacer - the rusty steel one that bolts to the arm itself. I used heat and a puller to try and pull it out, but it snapped. I have a new one on its way, but how do I stop it rusting itself together again? Has anyone found a cure - paint it perhaps?
These questions are probably are as old as the triumph is, so apologies if they have been answered before, I just can't find the answers.
