1 - 18 of 18 Posts
I've got play in my cush drive, don't know how normal this is. If I grab the cush drive I can move it from side to side quite a bit.
What? You mean we're only allowed one stupid question per day?
Hmmm... cush drive...
Click the pic for a good explanation and some detailed pics.
Not sure about how much play is within spec, but after only a year, you shouldn't be having issues yet.
A little play is normal even on a brand new bike. Most bikes I've owned have had a very small amount of play. If they didn't have some, it would be hard to disassemble them because the rubber would be wedged into the hub to tightly.
I've just checked mine Limey and there does seem to be a lot of side to side play. Never noticed it before, rides perfect so maybe thats the way they are. I'm sure other bikes I've owned didn't have the amount of movement this does though. I took one out af a Fireblade and it was tight to get back in??
Discussion Starter · #13 ·
On 2007-01-03 16:08, itchin wrote:
Seen it posted here a while back Limey where someone used old pieces of innertube to take up excess space/slack.
If its an issue they can repair it under warranty :-D :hammer:
Joh Bloor Special
I just checked mine Limey, and there is almost no play. I've done about 11,900 miles.
I quickly went to check. The bike was in neutral on the stand. No play at all in the cush drive but it may have been under a slight load. I can't see how something designed to reduce driveline lash should have any play.
· Banned
Okay, I wiggled mine too, then my wife walked in and caught me, very embarrassing.
All seriousness aside, mine had just an ever so slight amount of play in it....the cush drive that is.
kjazz
1 - 18 of 18 Posts
