1 - 20 of 25 Posts
Guys, I dropped my bike turning around in gravel today, squashing the gear lever into the dirt. When I got her back up & started, I couldn't get into first. Thinking I could go up & then down the gears, I shifted all the way into 5th. Now I'm stuck there. Really stuck. So stuck I had to have the bike towed 75 miles home.
Any idea what I've done & whether it's fixable by a rookie? I'm hoping I don't have to have it towed to the shop to get it fixed. I've spent enough on towing as it is...
Oh, that sucks. Went down in gravel myself a couple of weeks ago and broke the peg. Luckily, I didn't have any problems with the gear selector shaft.
Gear grief!
You can fix a bent shifter however, do be aware that Triumph builds in a "weak link" into the shaft for the shift lever.
All it is is simply a machined area inside the cover that is thinner than the rest of the shaft, when you stress the shaft by dropping the bike, that weak area will bend slightly, by doing it that way, they protect the fragile gearing and selectors inside.
Do a search or get a Haynes Manual, Bonniebabe, you really should have one anyway it's invaluable when working on the bike.
You may have a bent shaft from the sounds of your description. I seem to remember it's not a difficult job to replace one.
Good luck!
Thanks for the encouragement & advice. Sadly it turns out the I broke off one of the fork-type bits off of the gear selector rod. A pricey little misadventure. I'll have to follow sweatmachine's advice from now on... :eek:
Ouch! Do you mean the internals? I wonder how much that is going to cost? :eek: If your dealer is cooperative, could it be regarded as a warranty issue? The insides shouldn't be breaking from a simple drop.
Discussion Starter · #9 ·
If they find the piece in the oil sump, as they hope to, it will cost me $927 in parts & labor. Nauseating.
I'll talk to the guys at the shop about it maybe being a warranty issue. Thanks for the tip!
an 09 with a light drop better be a warranty issue. bring a big burly biker type with ya for negotiations... id volunteer, but im 3k miles away.. lol.
Ouch! Damn that hurts. They will be able to find the broken piece, there really is nowhere for it to hide.
Unfortunately, dropping the motorcycle is not considered normal useage, so it will not be covered by warranty.
Talk to them nicely though - maybe that gear selector fork was defective so the weak shaft didn't protect it right - maybe they can split the cost with you ort something. It's worth a try.
The big burley biker bit doesn't work - they usually have a bigger, burlier biker out the back, and anyway calling the cops is easy.
Discussion Starter · #12 ·
Thanks, propforward, for the additional info. When push comes to shove, I'll pay whatever it costs to get my bike back on the road......
Yikes! Now I don't feel so bad about dropping my padlock onto my tank and chipping out a divot of paint.
How about finding a part from a wreck?
quit dumping your bikes and you guys won't have any problems, sheesh!
I know this sounds harsh, but I have to agree with Sweat. Forty years, 11 bikes (dirt to 2 goldwings) I live on a dirt road in the desert, and I have never dropped a bike. I know it "just happens", but I just keep hearing it over and over. We have 2 guys at work that dropped theirs at parking lot speeds, 1 guy twice.
OK, now I'm officially an A-hole. :knockknock:
You've also officially just got off your lucky streak and will be dropping your bike shortly, just for mentioning it. (I hope not.)
Just like data loss on a computer, it's not if, it's when.
250K miles, and I have dropped my bikes three times, not including dirt bikes.
1. Rear Ended at a stop sign.
2. An Ass making a U-turn illegally in front of me.
3. Slippery root in my front yard.
You were lucky, not just good. It can happen to anyone at any time!:Dang:
Jim :cool:
Discussion Starter · #18 ·
Five weeks later... The guys at the shop finally got the gear selector fork from Triumph. The bit of the fork that snapped off was not in in the oil sump as they expected so the mechanics had to split the case. Yesterday they found the piece between a couple of the gears. I should be riding again by the end of the week. Sheesh, what an ordeal....
What a pain in the proverbial. At least they found it....
Glad you'll be out and about again soon!
5th gear
Ouch!!!! That had to hurt $$ wise. Lesson learned. I am SURE it wont happen again!!
The words "Splitting Cases" always makes me cringe!! Good luck from here on!!
1 - 20 of 25 Posts
