Hello again fellas.
I tried to fire up the Thunderbolt last night and couldn't get her to go. I checked both cylinders for spark. I have a nice blue spark on the right side but the left side has a very white, bright spark - not the good blue spark we are all used to. Any idea what would be causing this? Do I have a coil getting ready to go bad? I am using the original Lucas MA12 coils. I do not have another coil to check this. Any suggestions?
Also, I do not think the Amal is getting fuel to the cylinders. I have NO experience with tweaking these old Amals so any help would be appriciated. I took it apart and cleaned all the jets and made sure everything was clean. I did not put in any new parts because, based on what I know (which is not much) everything looked good. The slide is not loose in the carb bore, needle looked good, etc....
Any help with tuning the Amal or finding out why I have that funky spark on the left side would be awesome! Thanks guys.
Trav
Trav
