Nah, pretty straightforward: use something that won't mar the paint on the legs, like the edge of a piece of wood.
I took mine off while the forks were on the bike - popped them up and out of the retaining groove and then snipped them with metal snips. I knew I would not ever put them back on because the bike looks so much better without them.
I'm getting conflicting reports of this battery fitting a 2008 Triumph Bonneville. This is really the battery I want but I need to know if it will INDEED fit a 2008 Bonneville. I also am going to be doing the airbox removal kit from BC's and want to make sure it won't affect which size battery...
I'm about to re-shim the valves after finding a couple were down to 0.12mm on the inlet side and 0.20mm on the exhaust
the procedure says to lock the camshaft gear with the back lash gear using locking tool T3880330. is this just a pin? and if so what size will fit the hole?
looking at making...
Hi people.
Looking to upgrade my front assembly on my Bonnie 2002 as the piston bore has begun to leak slightly, this being a good opportunity upgrade if possible.
Would like to fit inch flat-bars, would the scrambler brake assembly be a direct fit me thinks.
Guidance would be appreciated...
I have a 2012 Thruxton, about a month old now that every once in awhile only turns over a split second when pressing the start button. Pressing it again causes it to turn over another split second but still fail to start. If I press and hold the start button, it will turn over a split second...
I just removed my rear fender and installed a new brake light. I also removed all turn signals. My tail light works but I'm not sure if the brake light is always on or not working. Front and rear brake application produces the same response, nothing. I plugged in the red to yellow, black to...
A forum community dedicated to Triumph Motorcycle owners and enthusiasts. Come join the discussion about performance, racing, cafe racers, bobbers, riding, modifications, troubleshooting, maintenance, and more!
