1 - 2 of 2 Posts
I have 93 Steamer which runs fine but can be a pig to start. Sometimes it is on the button, other times it just about catches before the battery gives up, although I have had the battery checked and it is OK. It has new plugs etc and the carbs are checked and good. I have read about the sprag clutch on earlier models, it is quite noisy, does this affect the starting in this way if it is dodgy? It looks like quite a task replacing it although I do have an early engine which apparently have an access panel
Any help or tips appreciated
Cheers
DiggerT
That certainly sounds like the starter sprag is not well :( The symptoms you describe fit it to a 'T' I am not personally familier with this inspection panel that you mention ?
Normally this is a bit of a job to put right :( , but there is plenty of information out there if you fancy tackling it yourself.
Here is a link to an archive thread
Clicky
[ This message was edited by: BigStripey on 2007-03-05 15:04 ]
1 - 2 of 2 Posts
