Wonder if you guys can help, went to start the bike this morning to go to work as usual but when i turned the ignition on the lights come on, the backlight on the instrument panel comes on but no status lights/mileage etc.
When turning it on the lights come on but the fuel pump doesnt go as usual and when i press the starter nothing turns over, just absolute silence.
If i turn the main beam on that status light comes on, similarly with indicators.
I had a look in older post on this forum and came across one that was promising suggesting fuse number 5 had blown, i have just replaced that one and checked every other fuse and none are gone, to no avail.
When i switched the bike on without fuse 5 in it was exactly the same as starting it with the fuse in, but a new fuse hasnt fixed anything.
The same post suggested disconnecting the battery and turning the ignition to reset something then reconnecting and trying again but this hasnt helped either.
I have taken the bike into work every day this week and when i got home last night i checkedt he oil and plugged the optimate extension cable in.
Initial thought is maybe the battery, perhaps some kind of power surge fried it or my optimate is knackered. I have taken the battery out and plugged it directly into the optimate and will go back in an hour or two and have another play about, but thought i would pop on here and see if anyone else had ideas or experience?
Thanks in advance.
James.
EDIT: Meant to say:
Its a '05 Daytona 955 on an '07 plate, has the factory fitted alarm
Thanks in advance.
James.
EDIT: Meant to say:
