1 - 20 of 210 Posts
UPDATE: Genuine Dealz now provides a custom cable service - http://www.genuinedealz.com/custom-cables/custom-battery-cable-assembly
Makes it really simple to get them pre-made to your specs!
This came about as result of discussion with OldnDumb, when I came across an E-Bay vendor selling Starter Cable kits for various bikes, Triumphs included.
The premise actually seemed sound - the price a bit steep for what it is - $75.
So OnD & I both elected to undertake this, he on the 1050 Sprint; mine on the 955i Daytona.
OnD actually was a little less tardy than me in ordering materials & actually completed his a couple of days ago.
The mod involves upgrading the cables for:
Battery Positive - Starter Solenoid;
Solenoid to Starter;
Battery Negative to Engine Ground.
The whole purpose is to reduce voltage drop to the starter, providing maximum energy from battery to starter motor.
I failed to take a comparative pic for my own cable set, but is essentially the same size-wise - 4 GA is 4 GA!
The project materials are 4 GA UltraPure Copper Wire and Tin-Plated Copper Lugs.
I bought some Cable sold by foot from an Auto Audio supplier on EBay (there are quite a few - shop around) - bought 8' and had a couple left over
If you were frugal, you can see 6 would be plenty.
The Lugs and Pellets I got from GenuineDealZ - with name like that, has to be good right?
Note that they also have an assembly service so if you buy the cable, lugs and heat-shrink from them, it will cost you additional $6 to have them pre-assembled.
I probably overdid it on the lugs - got the heavy wall items when in retrospect the std would have probably been plenty adequate.
Size of course is 4 ga 1/4".
We used different techniques for the cable assembly, more driven by what was at our respective disposal, as opposed to a technical preference.
OnD used a creative self-fabricated crimp tool (hopefully he will follow with pics as an addendum); I wanted to try another inexpensive method.
My lugs were soldered onto the terminals by use of Solder Pellets.
The lugs and wire were lightly coated in flux and then the lug was heated with Propane torch until the solder pellet melted; at this point the stripped cable end is inserted into the lug and when source heat is removed, it cools rapidly and the cable is securely fastened to the terminal.
This is the type of system I used (not same brand, but similar principle):
Alternatively, the lugs may be crimped onto the cable.
There are inexpensive 'hammer' (or vice) type crimpers available for ~ $20.
Or try your local Auto-Stereo Install Shop - you may be able to source some inexpensive off-cuts of 4 GA wire, as well as having them crimp the lugs for you.
The completed cables looked as follows:
Note that these cable lengths ^^^ were for 02-04 S3 configuration!!!
(the Solenoid/Starter cable could have perhaps been 1-2" shorter as it turned out)
The lugs for the solenoid were modified by bending at 90 deg and also filing them smaller to properly fit the solenoid terminals. That detail should be apparent in the cable pics and final assembly pics.
These following measurements supplied by dkyamada from post #29
Starter Motor to Solenoid - 16"
Solenoid to V+ Battery - 24"
Battery V- to ground - 27"
Use any measurements shown on your own cognizance - measure for yourself ideally.
Installation is pretty straight forward.
The Solenoid is located under the Frame Rear Cross-Member. I chose to replace the Solenoid to Starter Cable entirely, while adding additional parallel 4 GA cables for the battery positive (to Solenoid) and Battery Negative (to Engine Ground)
I elected to have both battery cables run under left side of sub-frame - the right side is already 'busy' with the main harness and the already tight interference of the Fuel Pump Power & Fuel Disconnects. It may have added a couple of inches to the Positive Cable to Solenoid length, but was the best routing in the circumstances.
You can see the difference is Wire Gauge in the following install Pics.
This is the Solenoid pulled out of its Rubber Shroud for access to execute the mod:
And after the new cables are fitted, prior to the Solenoid being re-installed in the Rubber Shroud/Mount:
These are final install pics:
The Results:
In order to check the voltage while cranking, I had the bike on side-stand, in gear and with clutch lever tied to bar with TieWrap.
This will allow the bike to crank, but not start - which was desired condition for test.
Also note that Engine had not been started in 24 hrs and was 'cold' (sic - temp in garage was about 90F).
Also during testing, the lights were disabled. (note that this is normal starting condition anyway - just wanted to avoid any unnecessary battery drain so the charge would be similar for both tests)
OEM Condition:
Per above set-up, with Igntion on (no lights) - 12.3V
Cranking Voltage:
11.05V at battery;
9.6V* between starter terminal and starter body.
* it was even lower initially - ~ 9.05 - when re-tested after about 20 secs of cranking, it came up to the 9.6V level.
4 GA Upgrade:
Ignition On - 12.3V (same)
Battery Volts while Cranking - 11.05V (same)
Starter Volts - 10.9V
So picked up 1.3V with the new cables (~14% increase).
And most notably the total loss in the new cables amounts to only 150mV!
Note that there was no charging of the battery from the 'before' to the 'after'.
The result is probably best illustrated by the speed at which the engine turns over as a result:
See/hear the difference in this before/after Video
Conclusion - For about $25 and 3 hrs of leisurely paced labour, very much a worth-while mod.
Should be a lot kinder on the Sprag with greater torque from the starter motor!
Note that the total 'sag' at the battery should be less with the engine fully warmed up, with less viscous oil. And conversely of course in the Frozen Tundra, you could expect greater sag.
Regardless of starting temp however, the loss to the starter should be much improved over the standard cables.
CAUTION: If you plan to terminate the cables yourself, it is CRITICAL that a flawless connection is made - that means the crimp or solder joint needs to be perfect.
This is a HIGH CURRENT circuit and potentially disastrous if executed poorly.
If you do not possess the equipment or capability to execute this, then leave that part to someone else - visit a car-stereo store or similar to have them crimp the lugs for you.
...Oh, and the first picture you linked needs fixing!
I see that now - tried to fix and ran into the 6 image limit thing:
here is associated text plus pic:
The picture below from my compatriot OldnDumb, shows the difference between the original Starter Cable & a 4 GA element:
The size differences were commensurate on the 955.
Awesome DEcosse! Serious improvement and a must do for those of us with slow cranking issues. I'll be a starter for this mod!:D
Interestingly though, I pulled my starter apart a few weeks ago and gave it a clean out. It wasn't too grubby inside and I didn't expect any difference after install. I was wrong and it's now cranking very well. Still got me stumped as to why, but I'm not complaining.
Great work from DEcosse and OldnDumb. A good fix for a problem I didn't know I had. The video clearly demonstrates the point though.
DEcosse, I'm curious about the starter cable kits you saw on eBay. I did a search and couldn't find the kit your referred to. I know you thought they were expensive but did those kits appear to be quality items good for the job?
To me $75 doesn't sound too bad compared to the time it would take me to source and procure materials and make up my own leads. Usually cost benefits are of little concern to me - the satisfaction of doing the work myself is what motivates me. But in this case I don't see much joy in crimping lugs so just buying a ready made kit appeals. This time I'm going with the old saying "hard works pays off eventually but laziness pays off now!"
If there are Triumph employees on this board, they should be taking notes, re. R/R, head light wire gage, and finally this - starter mod. If they don't incorporate this simple improvements/ fixes in to new S3 models, it would border on negligence.
Discussion Starter #12
Don't know if I would go that far on this one rnexussix - it's not that it's technically under-sized for the current - consider this one more an upgrade/enhancement for better efficiency. I think most bikes would be similar in this area.
Also the headlight wiring on the 1050's is MUCH better than the 955s.
It all comes down to cost in the end - although hardly criminal added expense!
Besides - what would I ever do with myself if these things were perfect? :p
Have you ever mentioned an internet forum as a reference while speaking to anyone in the motorcycle industry? Try it and be prepared to witness extraordinary eyerolls. :D
Besides, in this instance I feel certain they are already aware of Professors Ohm and Kirchhoff. :D
@oldndumb: I know what you mean ... I happened to mention a solution from this forum to a mechanic and got an eye-roll from him. So, I found another mechanic/shop.
@ DEcossee; the mods you described go further then just marginally improving/enhancing performance. I can see substantial increases in overall bike reliability, MTBF increases for stator and R/R. Better rider visibility and improved night time vision for a rider (in case of headlights wiring mod) and hence improved safety, all at a cost of using heavier gage wire and a better r/r components. You guys are too modest. I seriously hope Triumph is taking notes.
Once again thanks to DEcosse & OnD for this awesome mod!
My parts arrived from Genuinedealz on Monday and I've just completed the mod using DEcosse's method.
My bike has never cranked with soooo much vigor. Fantastic and I'm looking forward to showing my mechanic on Saturday, as I think he'll be impressed.
my bike recently begain having trouble starting while hot, even with a new battery in May. hope to complete this and a few other mods to the electrical system before i kill any expensive parts...
thanks to DEcosse & Old'nD for their time/effort in finding a worthwhile improvement and sharing the details on how-to.
Discussion Starter #19
Ferris, mind posting the Genuinedealz parts cart/list? Thanks.
The link is my first post - lugs and the solder pellets and even the heatshrink if you need it are all easy to find from that single link.
You can buy the wire from them or source it separately.
They will even manufacture the cables for you at $1 per 'end' over cost of the materials i.e. $6
1 - 20 of 210 Posts
