Not a problem, You should buy a service manual though, either from Haynes or Clymers. Just remove your fuel tank, then your airbox. To remove your air box you will have to undo the thermostat housing and the intake duct's from the fairing. plus you will have to disconnect some hoses and a sensor,make sure you remember where everything reconnects on reassembly. Once you remove the airbox the IACV will be right there on top of the throttle boddies. There will be 3 hoses running from the IACV to the intake manifold, check to see if any are cracked or split.
