1 - 2 of 2 Posts
I finally split the cases on the motor I screwed 2 years ago, and there it was. The passenger outside rod bearing had spun. Luckily, I didn't drive on it but a 1/4 mile with the knock, and the damage to the crank appears to just be in need of a slight polish. I'm guessing the rod and piston are fragged from the vibrations, but do you think the crank is still usable? I didn't go over 4k on the motor after the noise, and it wasn't extremely loud.
Sooooo also, if anyone needs motor parts, I'm posting them up in the classifieds! haha
Discussion Starter · #2 ·
Also, just so you know, the reason I'm convinced is that I used a crummy oil filter. I got talked into using an off brand by a friend, and within 150 miles the bike was dead. I won't mention the friend or Fram's company name like that.
K and N or OEM from now on till the day I die!
1 - 2 of 2 Posts
