1 - 10 of 10 Posts
Hey ya'll,
I am just coming up on my 18k service and am going to need to change out my sprockets and chain. I am currently in Phx, Az. and was wondering what the average cost of replacing them was? Where did you get your parts, brand, model? Etc, etc.
Thanks for your input in advance!
Mark
if your out of warranty, id do it yourself. Its super easy on the speed 3. You dont need a stand or anything...though it makes it a little easier. I have faith in you!!!:D
How do you install a new rear sprocket without a stand?
Duh...answered my own question.
Six nuts and it slides off the swing arm to the left. What a sweet design.
Thanks lads, I'm still on warranty, but what about cost? For a site of S3's and no replies?:confused: Don't you lot ride enough to have your sprockets and chain changed? Odd...?
Mark
I do ride enough, i'm just too poor to pay the dealer to do something so easy. Id much rather pay the supplier for better sprockets and a better chain. (vortexracing.com):p You goto the dealer for warranty...and your only getting the OEM stuff, which is good, but not the best.
though I only have 8000 miles on my S3 since I bought it March 19 2008. But I think thats quite a bit for a single father who drove a company van to and from work everyday. Im laid off now, but with my next job, unless they give me a truck to drive, my speedy WILL be my primary mode of transport!:p
I would think any dealer would sell and install accessory parts if you order them through him. If you want to save a few bucks, replace the chain and sprockets yourself using a clip type master link. (You can cut the old chain off with a dremel tool.) Then drive the bike, gently, to the dealer to have a proper master link installed. If have that done as part of some other work, inspection for example, they will probably do it quite cheaply.
I do ride enough, i'm just too poor to pay the dealer to do something so easy. Id much rather pay the supplier for better sprockets and a better chain. (vortexracing.com):p You goto the dealer for warranty...and your only getting the OEM stuff, which is good, but not the best. :p
Yes, but doesn't vortexracing make aluminum sprockets? In which case you'll never get 18k miles out of them. The steel ones are built to last.
Discussion Starter #10
Thanks for the insight lads. I think when me warranty is up I'll definitely do all the work meself. I found a standard OEM kit online for $174 and the rest are $190 and up.
Cheers!
1 - 10 of 10 Posts
