1 - 13 of 13 Posts
Hi
Wonder if you could help me. I am thinking of upgrading my bulbs to orsam nightbreakers.
Does anyone have these fitted and if so are they a good alternative ? Any other recommendations ?
Secondly, what sizes do I require for the 2 dipped and full beam ? Atre they all H7 ? I am currently out of the uk and cant check on the bike.
Thanks for any help/advice
cheers
steve
Well, I have the Nightbreakers, and am very impressed with them........over the standard lamps.......
gotta admit, never ridden with Hid's though.............
Hi
cheers
steve
Steve--Yes, they are all H7 bulbs. I put these on my '06 and they do light it up better than the stock bulbs. The controversial issue has to do with the life of the NightBreakers. Hopefully, I won't be disappointed in that regard but it's too early to tell since I made this switch just a couple of weeks back. One thing is for sure, the NightBreakers are not as good as HID but they are easy and fairly inexpensive to install. That's worth a look, I would say. --Ken B.
I put Osram Silverstar (only 50% brighter) H7 in my dipped pair - only had to remove screen and cockpit infills to get to them. When it came to main beam I baulked at removing the instrument binnacle - luckily it was in for a service and warranty work at my dealer, so they did the main beam for me. It did make quite a difference, especially also lifting the aim a smidge!
ok... thanks, were would I get HID's from/fitted. How much they cost ?
I can personally recommend these.
Cheap and worked very well with couple of Hondas.
Those are with normal ballasts so you need to find more space.
Installation is plug and play.
I dont have Spint so i cant help you more.
Maybe someone has more experince with Triumphs.
No more halogens to me, never!!! :cool:
1 - 13 of 13 Posts
