Max,
It is possible, but not easy to remove the rails. The grab rail is a piece of cake to take off.
If you decide to remove the rails, you might want to go to a Dealer and get/burn a copy of the Installation instructions. They've probably got some lying around.
Good luck!
Steve
Rails come right off with 4 bolts per side, takes less than
5 minutes to do.
yes the grab rail also comes off, and if you get the Corbin
seat, they supply a new latch system, that uses the old
grab rail bolt area, and they fill-in the seat notches.
if you want a real clean look, 4 more bolts will remove
the rear peg assy's. This lets the single sided swing arm
really show.
Finally a rear fender "Tidy" and you have the complete
stripped down sport bike look.
I can put it all back on, with the bags, in under 1/2 an hour,
a big reason why i bought this bike.
This may help. Not the greatest picture and you can't see all the way to the rear. They used the red loctite to install them so it takes a little torque to bust the bolts loose but it is very simple to remove the rails.
My Pics
[ This message was edited by: LoVel on 2006-12-27 07:54 ]
