1 - 9 of 9 Posts
Good afternoon All, hope your all staying cool in the heat wave.
The bike is a 78 750 5 speed and i am curious if my speedometer vs tach is correct. In 5 the gear at 2500 i am seeing about 50mph, at 3000 about 60 and 3500 about 70. Sound about right to ya'll?
mark
Great to have you on board. Aren't the classic Meriden bikes great? But what heat wave? :) It's always hot here in South Africa....
'79 T140E, gearing / sprockets are 'standard', i.e 47tooth rear sprocket.
3000revs, 3rd gear ~ 30mph
3000revs, 4th gear ~ 40mph
3000revs, 5th gear ~ 50mph
4000revs, 5th gear ~ 70mph
This figures have helped me out over several thousand miles of riding with a non working speedo when the p.o.s. Veglia speedo drive has failed.
manual states that in 5th gear 10mph = 627revs, but I guess the rev counter wont be particularly accurate.
Does your bike have a 45tooth rear sprocket?
Thanks teologie, I have no doubt that South Africa is very warm.
Pointing at the same clock position seems about right- till my tach rotates 90° to the left. Of course i expect that in the southern hemisphere they rotate right....
I should go count my rear sprocket.. manual states 47 tooth. It also states 1 to 1. I guess you can multiply up using 627. 6*627=3762rpm=60mph. Sound logical?
mark
10 mph @ 627rpm sounds about right.That's 6270rpm @ 100mph , 8778 rpm @ 140 mph.
4000 @ 70 mph would give 8000 @ 140 mph,so something's not right.
With 20/44 sprockets,you'd be spinning 4100 rpm @70 mph;not with 20/47.
On a 78 with stock gearing and wheel size in fifth gear every 500 rpm equals 8 mph.
2000 = 32 mph, 2500 = 40, 3000 = 48, 3500 = 56, 4000 = 64, 4500 = 72. I have had both of my gauges rebuilt by Nisonger and they check out within a couple of mph of what they should be. I was surprised that it was the tach that was really off.
1 - 9 of 9 Posts
