1 - 3 of 3 Posts
Greetings,
What is the standard drive ratio for rear wheel mounted speedometer drive? I'm going to buy a replacement speedometer and probably need to replace the drive also. I have a 69 t100r with a 2/1 ratio drive.
Thanks for all replies
The ratio for the drive you are replacing should be stamped on the drive itself. At least that has been my limited experience.
regards,
Rob
1 - 3 of 3 Posts
