Does anyone know if the TT600 Speedo Drive is the same as any other Triumph/Other makes????
Please help as Triumph want £110/$200!!
Ben
It might be the same as other Sagem injected Triumphs, but I don't know if the axle diameter is the same. You could always go with a Veypor or some other kind of speedo in lieu of the faulty one, although it would mean having one not working and one working.
It's an electronic dashboard typically used on bicycles and dirt bikes. I have a simplified version called a Trail timer or something on the Husqvarna. It's just an alternate speedo. The pickup fails at regular intervals, since the magnet inevitably gets damaged or loses it's magnetism as you remove and replace the front wheel.
