A friend has just got a 2008 Speed Tripple 675. In short , it fails to start ! When the ign is turned on, the fuel pump just runs & doesn't stop , then when you crank the starter , the Speedo flicks from rest to 150 & back & that is pretty much it ! Ideas on a post card please !
Sent from my GT-I9300 using Motorcycle.com Free App
Is it a Speed Triple or Street Triple ?
At any rate a dealer should be able to hook it up to the computer and get the error codes.
It's a Street Tripple. Sorry. It was battery too. Down to 10.24 when we recovered it. New battery perhaps. Been on there since 2008 ? Thanks guys.
Measure the voltage across the battery when running and if below 14.25vdc - check into getting the regulator rectifier replaced as part of the Triumph RR recall.
Either way, contact your dealer and see if the bike is on the books for the recall. A bad RR will take out a battery.
