1 - 8 of 8 Posts
Hi all
Wondering what year speed triple wheels will fit a 2000 ST
Looked around and have not found any solid answers.
George
Basically any 1997-2004 Speed Triple, 1997-2004 Daytona 955 and 1998-2004 Sprint ST all share the same exact wheels.
I even think 2005-2009 1050 Sprint and S3 will be able to fit?
Triumphite,
I am not certain on this;
but am pretty sure that the Daytona's (955's) have a 6" rear wheel as they take a 190 rear tyres as std, and the Sprint is a 5.5" wide rear rim taking a 180 rear tyre as standard.
cheers
DaveM:cool:
Dave is correct, however I beleive that some early sprints came with the 6"wheel as stock and was kinda hit or miss depending on the bike.
I may be wrong though.
For wheels that fit all SSSA rear wheels will fit as well as the fronts. IIRC the 1050s use a different speed pickup and has a different set of spacers. With a wee bit o work it can be made to fit, I beleive Decosse has an example of how to convert that some where on here.
I would assume that your looking to use the 1050 S3 so youd have to run a new spacer and modified speed pick up to use the front, the rear will bolt on though.
2005 to 2008 S3 and Sprint use the same wheels but as far what ones you can use I think only up to 2007 S3 because of the front brake change in 2008.
oh yeah cal just reminded me, if you use the 1050 wheels you'll need the 1050 rotors as well. They have a different bolt pattern.
This also applies to later Daytona models too, as they use 5 bolt rotors, compared to the 6 bolt used on the Sprint ST.
Mark
Discussion Starter · #8 ·
Wheels
Wow alot to look at! I ask because Carroizerra makes forged aluminum wheels for the S3. Wanted to know if the S3 wheels would fit the ST. Alot of $$$ but man are they pretty!
George
1 - 8 of 8 Posts
